JoeliusZ28's LT1 cam swap thread
  • You know it's afternoon right now, right?
    • good deal Joel! Did you over tighten the plastic low oil temp sensor? If so.... join the club
      • Originally posted by Superman09 View Post
        no, i broke it hitting the engine internals somehow. Happened almost immediately so ill have to be careful putting it back in.
        • [ATTACH]11140[/ATTACH]
          [ATTACH]11141[/ATTACH]
          [ATTACH]11142[/ATTACH]
          [ATTACH]11143[/ATTACH]
          [ATTACH]11144[/ATTACH]
          [ATTACH]11145[/ATTACH]
          [ATTACH]11146[/ATTACH]
          • The new cam finally has a home!
            • Can't tell from the pics but did that end up being a 4-bolt main block?
              Originally Posted by 1BADAIR
              • Originally posted by adamss View Post
                no fbody lt1s are factory 4 bolts mains. you can see in the pic below the timing set the one main cap just on the end... its a two bolt.
                lookin good, we are about at the same spot....
                  yea f-body LT1s are two bolt main. There were some lucky 94s and 95s that got the corvette block (4bolt) when supply was short.
                  Was just curious But i see what you mean in the pic
                  • Originally posted by bmwmcars View Post
                    not true, they were not SUPPOSED to, but GM being GM did in fact use some Corvette blocks when the f-body ones ran short on supply. As stated some slipped through in 94 and 95.
                    I was not lucky enough to get the 4-bolt main, but i cant say I expected to. There are no production numbers on them, but they dont seem to be very common. I would say 10% at the absolute MOST. probably somewhere in the 2-5 range though.
                    • progress looks good, wierd seeing how your opti is drived
                      1996 Trans Am. 355 LT4 + some go fast mods.
                      www.360icons.com
                      _ Do you have what it takes to become an icon?
                      _
                      <Atmosphere> Call of duty mw2 summer 10' Ladder
                      Gamebattles.com
                      Perlsh
                      • Did you take apart the Opti to see if that was for sure your problem?
                        Check out my 'bird: http://www.mifbody.com/vbulletin/sho...256#post325256
                        • Cam swaps with A/c suck
                          • Originally posted by Will View Post
                            nope. I will though.
                            yes they do. i sat there for a few minutes pondering deleting all that crap. but its nice to have when you got a date in the car....well as a matter of a fact thats actually the ONLY time mine ever gets used.
                            • Did you get the old cam out yet? Where did u move the condenser to?
                              • Originally posted by klrlt1 View Post
                                they move out of the way pretty easy, its not really that bad, maybe on a lt1 but idk since i run with the ls1 pack
                                The LS1 or Go Home Crew
                                ASE master certified
